aggregator
  • Jul 28, 2015 7:21 AM UTC
  • 60 views
Hi
I am using an aggregator to group polygons by two different attributes. Fme returns no error and seems to work reasonable (494 obj. before, 44 obj. after aggregation) and reports 44 features written.
However the actual number in the db is still 494.
What am I missing?
  • Jul 28, 2015 4:18 PM UTC
If you are going to update records in an existing DB table, all existing records other than updated records will also be preserved unless you delete them.
Isn't it such a situation?
Takashi
  • Jul 28, 2015 4:23 PM UTC
Hi Takashi
Unfortunately no. The writer is in truncate mode, which deletes all existing records before updating.
