Aggregate Attributes by date and by Run
  • Oct 19, 2016 9:13 PM UTC
  • 6 replies
  • 100 views
Hello All,
I want to aggregate attributes (Clientid) by Run and by date. Please see the attached spreadsheet
Forum|alt.badge.img+63
If you set up an Aggregator and have it group by Bookingdate and Run, then create a list you should be able to get what you're after.
You can then use a ListConcatenator to create a new attribute with all the ClientID's per unique combo of Bookingdate and Run. I've attached a template with a workspace that shows this.
Hope this helps.
aggregation.fmwt
  • Oct 20, 2016 2:17 AM UTC
Hope this helps.
aggregation.fmwt
Another option. If the goal is to concatenate Client IDs for each group of date+run, the "Attributes to Concatenate" parameter might also be helpful.
  • Oct 20, 2016 4:23 PM UTC
Hope this helps.
aggregation.fmwt
Hello,
Thank you for the reply. I want to count distict booking ID with run. The FME shows the list of client id. But it will be great if I get sum of client id and distict count of booking ID by the run. Thank you again.
itay
Forum|alt.badge.img+19
  • Oct 20, 2016 5:13 PM UTC
Hi,have a look at the count attribute for a distinct count and the attributes to sum option.
  • Oct 20, 2016 5:21 PM UTC
Sorry, I didn't get you. What do you mean to look at count attribute?
itay
  • Oct 20, 2016 6:11 PM UTC
In the aggregator there is a setting (Count Attribute) to preform a distinct count per group defined by the attributes in the group by setting.
