After using the "Points on Area Overlay" function, how to read the result?
  • Jan 17, 2018 11:56 PM UTC
  • 5 replies
  • 85 views
I have a polygon layer(shapefile) and points layer(from csv) and use "Points on Area Overlay" function to count how many points within each polygon.
But I don't know how to read the result. I have link the "area" output to a writer in shapefile format.
In the inspector, I found that all _overlaps fields are 0. I suspect there is something wrong.
Best answer by austinh
_overlay or _match > than 0. Use the tester transformer.
austinh
Forum|alt.badge.img+4
  • Jan 18, 2018 1:04 AM UTC
austinh
_ovelap > 0
  • Jan 18, 2018 2:56 AM UTC
Hi @yyj130, the PointOnAreaOverlayer could generate unexpected result if the coordinate system for the Point features was different from the one for the Area features. Make sure that those features have the same coordinate system.
  • Jan 19, 2018 5:58 PM UTC
Thanks! I adjust the coordination system and it works!
Thanks! I also adjust the condition and it looks good right now!
