Affine Warper without Using Offseter
  • Aug 20, 2024 9:01 AM UTC
  • 187 views
aharport
Forum|alt.badge.img+4
Hello, I'm trying to use AffineWarper to transform 3D data (x,y,z) from a local coordinate system to a national coordinate system. This works well, but unfortunately the z coordinates are not changed. They retain the heights of the local system. Does the transformer only work in 2D?
The offsetter doesn't help me here because the difference between the z-values ​​is not the same for all coordinate pairs.
Please help. Thank you.
Best answer by DanAtSafe
We will notify you here when the AffineWarper works with 3D features - whenΒ FMEENGINE-15629 has been resolved.
DanAtSafe
Forum|alt.badge.img+23
  • Aug 20, 2024 4:28 PM UTC
Hi @aharportΒ Unfortunately the AffineWarper only works in 2D.Β  Support for 3D affine has already been requested viaΒ FMEENGINE-15629.
aharport
  • Aug 20, 2024 5:56 PM UTC
Hi, what does it mean? When the Transformer will support this feature?
DanAtSafe
  • Aug 20, 2024 6:12 PM UTC
aharport
  • Aug 21, 2024 5:48 AM UTC
Thank you very muchπŸ™ŒπŸΌ
