Adding a line to another lines, and breaking at the intersection?
  • Jun 25, 2020 1:32 PM UTC
  • 67 views
thewindgone
there are two sets of line feature. The lines of the first set are interrupted, figure 1. The second set is a whole boundary line extracted from a polygon, figure 2. The coordinates of point 1 and point 3 are equal, so do point 2 and point 4. Now I want to add the bottom line from the second set to the first set, leaving this yellow line, and breaking at the intersection. What should I do? Thank you so much.
gio
Forum|alt.badge.img+15
  • Jun 25, 2020 2:02 PM UTC
@thewindgone
Everything rectangular?
Use areabuilder on both sets eand then clip f1 with f2. (maybe seom segment snapping if topology is not sound)
Coerce result back to line.
Greets
thewindgone
  • Jun 25, 2020 2:18 PM UTC
@thewindgone
Greets
Hi, I clip a face with the other, and then convert it to lines. But all lines are complete boundaries of each polygon, not broken lines.
