Add XML fragment using XMLUpdater
  • Nov 23, 2020 1:30 PM UTC
  • 0 replies
  • 35 views
I have several XML files with the following content:
 <gmd:contact>
  <gmd:CI_ResponsibleParty>
   <gmd:organisationName xsi:type="gmd:PT_FreeText_PropertyType">
    <gco:CharacterString>Information in main language</gco:CharacterString>
    <gmd:PT_FreeText>
     <gmd:textGroup>
      <gmd:LocalisedCharacterString locale="#ENG">contact info in English</gmd:LocalisedCharacterString>
     </gmd:textGroup>
    </gmd:PT_FreeText>
   </gmd:organisationName>
  </gmd:CI_ResponsibleParty>
 </gmd:contact>
I will like to add contact in other language, for example:
 <gmd:contact>
    <gco:CharacterString>nformation in main language</gco:CharacterString>
    <gmd:PT_FreeText>
     <gmd:textGroup>
      <gmd:LocalisedCharacterString locale="#ENG">Contact info in English</gmd:LocalisedCharacterString>
     </gmd:textGroup>
     <gmd:textGroup>
      <gmd:LocalisedCharacterString locale="#FRE">Contact info in French</gmd:LocalisedCharacterString>
     </gmd:textGroup>
    </gmd:PT_FreeText>
 </gmd:contact>
I am using an XMLUpdater with the following attributes:
  • Update type: Insert as last child
  • XML Path: //gmd:contact/gmd:CI_ResponsibleParty/gmd:organisationName/gmd:PT_FreeText/gmd:textGroup/gmd:LocalisedCharacterString
  • Value Type: XML/XQuery
  • Value: fme:get-attribute("text")
Using this values, I get the following result:
 <gmd:PT_FreeText>
     <gmd:textGroup>
      <gmd:LocalisedCharacterString locale="#ENG">Contact info in English Contact info in French</gmd:LocalisedCharacterString>
     </gmd:textGroup>
How do I have to do to get a new brach, not just the text added at the end of the previous text? How can I indicate the locale attribute?
