Add csv data as new attribute
  • Dec 22, 2021 5:46 AM UTC
  • 122 views
abinash
I have a shape file which has several names in it. These names comes under 6 departments. So i want to create an attribute named as department. I have the csv file where it is mention which name comes under which department.
Forum|alt.badge.img+63
You can use a DatabaseJoiner to do that, or if you are already reading the CSV into FME a FeatureJoiner or FeatureMerger.
In all cases you can set the column(s) to join on.
