accumulate all input attributes in one attribute separated by comma after using Dissolver
  • Apr 26, 2022 12:47 PM UTC
  • 279 views
nicolae.soare
Forum|alt.badge.img+7
Hello,
I am using Dissolver to remove common boundaries and create larger areas based by an attribute.
Next step was to calculate the areas of areas from which I created the large ones - DONE (Accumulation -> Attributes to sum).
Now I would like to create a list of some attributes from small areas and put them in another attribute separated by comma ( ex: name, id of old small area).
Can we do this in Dissolver?
Thanks!
Nicu
Best answer by dustin
In the Dissolver, choose the Generate List option. Give it a list name, and then specify the attribute you want to accumulate. After the Dissolver, insert a ListConcatenator and choose the previously created list. This will concatenate the values separated by the Separator Character.
dustin
Forum|alt.badge.img+36
  • Apr 26, 2022 12:56 PM UTC
nicolae.soare
  • Apr 27, 2022 8:25 AM UTC
Thank you! It worked great.
Nicu
