A simple transformation from AMG84 to MGA94 Z51 fails using excel input. Why?
  • March 16, 2016
  • 65 views
fmelizard
Forum|alt.badge.img+22
  • March 16, 2016
If you are using excel are you creating new columns or updating existing?
You need to reprioject the columns not the actual data set
Use the attribute reprojector
erik_jan
Forum|alt.badge.img+26
  • March 16, 2016
Yes, AttributeReprojector is the transformer to use. Reprojector expects a geometry, which will not be available in the Excel format. The best way is to copy the attributes into two new attributes first and then reproject the new attributes as they will be overwritten by the new value.
darkspatiallord
Forum|alt.badge.img+8
Let us know how you go @philmattinson
This is my proper account just resubmitting
