3Dtiles show error how to fix geometricError ?
  • Oct 8, 2024 5:21 AM UTC
  • 98 views
linmeng
Observer
I am a Chinese student who uses FME software to read shp files and create 3Dtiers files. There is a problem loading and displaying now. As shown in the video, there is an issue with zooming in and out.
Others' 3dtiles were generated using other software and did not encounter this issue. I'm having problems using FME now, how can I solve this. Please help me. My English is not very good. Can you understand what I translated using translation software.
I searched for some 3dtiles files and someone said it was a geometricError parameter setting issue.
Where can i set the 3dtiles geometricError ???
please help me .
I am bad in English.
my Emial 1985425275@qq.com
FME USE THIS .
Maxinum Number of Triangle Faces Per Tile  Trying to set 100 and 1000 times, but it doesn't work。
Where can I set parameters???
Someone told me that there is a problem with the geometricError parameter and it needs to be corrected。
Hom to ???
saraatsafe
Forum|alt.badge.img+13
  • Oct 11, 2024 10:33 PM UTC
Hi @linmeng, thanks for your post!
I don’t think a “geometricError” parameter exists; it sounds to me like that’s something that might exist in metadata instead.
As for your data, it looks like your tiles might be offset or maybe in the wrong unit. Are you able to check on the Coordinate System of your 3D tiles? You can look into using something like a CoordinateSystemSetter, Reprojector, or Offsetter to maybe nudge your tiles into the correct position.
