3D LInes with Z and M
  • Oct 29, 2020 10:00 PM UTC
  • 61 views
richardnairn
I am trying to extract vertexes from a shape file that has 3D Lines with both a Z value and an M value. I am trying to extract the both the Z and M value but I don't see a way to do it. Vertex Extractor will only give me X,Y,Z
@Richard Nairn​ VertexExtractor drops the measures. If you want the data as a series of points in the same way that VertexExtractor presents them, plus the M then you can use:
  • Chopper - By Vertex & Number Vertices = 1
  • MeasureExtractor
  • CoordinateExtractor
I've attached a small example workspace
richardnairn
  • Oct 29, 2020 10:33 PM UTC
Thanks, I will give it a try.
