License server calling closed ports
  • Jul 19, 2021 8:04 AM UTC
  • 65 views
oliver.morris
Forum|alt.badge.img+14
We have an issue where the license server (flex) is going through loads of ports which are closed before finding an open one, as a result everytime we try to run FME it hangs for about 30s waiting for the license ping back, is there anything we can do to try to consistently use an open port? We dont seem to have issues with other licenses that are hosted on that server.
Best answer by redgeographics
Yes, you can specify which port numbers it should use in the license file: Specify Port Numbers Used by FlexLM
Forum|alt.badge.img+63
oliver.morris
  • Jul 19, 2021 2:05 PM UTC
thank you @Hans van der Maarel​
