Unable to access API using HTTPCaller
  • Oct 14, 2019 12:31 PM UTC
  • 222 views
Hi
I am trying to connect to an open data API which contains geoJSON using the HTTPCaller. However I am getting the following error message: SSL peer certificate or SSH remote key was not OKI
I was able to get the geoJSON when I copied the API URL directly into the IE browser.
Does anyone know what settings I need to set on the HTTPCaller to be able to access the geoJSON through FME?
I am using FME2019.1 Desktop
Thanks,
Best answer by david_r
In the HTTPCaller, try turning SSL certificate validation off (under client options).
  • Oct 14, 2019 12:34 PM UTC
I just answered my own question. I set 'Verify SSL Certificates' to 'No' in the HTTPCaller and this enabled me to read the API successfully.
Thanks @david_r I just figured that out too!! :)
