Serial Devices connections and responses
  • Jan 26, 2023 10:51 PM UTC
  • 60 views
olly_egw
We have a custom application that calls and polls telephone numbers using an analog modem on COM1 port. I would like to port this application to FME and I have been unable to find any native transfomers/readers/writer that can communicate with COM Port1.
Question:
  • Can FME natively communicate with COM Ports ?
  • If so, how is this done.
  • If not, any suggestions on how to make with work
Best answer by daveatsafe
Hi @olly_egw​,
There are no FME readers or transformers that can communicate with the COM ports, but you could use the pySerial module within the PythonCreator transformer to activate the modem and return a feature for each call.
To install the pySerial module, please follow these steps:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop/Workbench/Installing-Python-Packages.htm
The pySerial documentation can be found at https://pyserial.readthedocs.io/en/latest/
A good starting point for using the PythonCreator can be found at https://docs.safe.com/fme/html/fmepython/getting_started.html
daveatsafe
Forum|alt.badge.img+24
  • Jan 26, 2023 11:21 PM UTC
Hi @olly_egw​,
olly_egw
  • Jan 26, 2023 11:51 PM UTC
Many thanks @daveatsafe​ .
Was hoping to have a no code solution; but was expecting a python outcome 👍
hkingsbury
Forum|alt.badge.img+73
  • Jan 29, 2023 7:03 PM UTC
Thats a really cool use case!!
as with @daveatsafe​ my answer was python. One thing to consider is how are you going to do the polling? If you do it within the workbench you will constantly be using a license/engine. So it is probably better to set a schedule for every X minutes to run the process.
