Receive data through an API
  • Jun 3, 2020 3:23 PM UTC
  • 47 views
mr_fme
Forum|alt.badge.img+9
I have a link, an authorization and a token, to receive data through an API, how can I do this in FME? Could someone give me an example?
Thank´s
Best answer by david_r
The HTTPCaller is your friend, there are a lot of examples if you search for "HTTPCaller" on the forums here, e.g. https://knowledge.safe.com/questions/108354/api-call-from-fme-httpcaller-does-not-work-but-api.html
This is also a great starting point: https://knowledge.safe.com/articles/92720/how-to-access-an-api-using-the-httpcaller.html
  • Jun 3, 2020 3:26 PM UTC
mr_fme
  • Jun 3, 2020 3:43 PM UTC
@david_r,
Your reply in https://knowledge.safe.com/questions/110636/received-http-response-header-http11-401-unauthori.html solved my problem.
Thank´s
  • Jun 3, 2020 3:49 PM UTC
Great, am glad to hear that you found a solution.
