OneDrive Authentication
  • May 23, 2019 12:30 PM UTC
  • 5 replies
  • 97 views
I am trying to add a Reader to a OneDrive Excel sheet. When I select 'Add Web Connection' to the 'Microsoft OneDrive (Graph)' Web Service, the Web Service Authentication but the windows is empty and won't load anything?
Anybody has had this issue?
Hi @nademmy,
I just tried this workflow and you should see something like this:
I tested this in build 19253. Can you share which version of FME you are using?
Some Other ideas to troubleshoot this:
- Are you using a proxy?
- Can you reach https://login.microsoftonline.com outside of FME?
- Did you modify the Web Service Definition for Microsoft OneDrive (Graph)?
- Did this work before or is this the first time you are using the OneDriveConnector?
  • May 23, 2019 4:42 PM UTC
Hi @nademmy,
Thank you for your answer.
I am using the 2019.1 version of FME. As for the other troubleshooting ideas, this is my first try with reading from OneDrive, I am not using a Proxy and never modified the definition of the Web Service. I will definitely try to reach out to Microsoft
If you go to this site in a browser: https://login.microsoftonline.com
Can you login successfully?
Also, 2019.1 is currently still considered a beta version. For production workflows please consider using the official release.
  • May 23, 2019 5:07 PM UTC
Yes, I can login from the site, but from the workench I don't get to see the login page. I guess I will switch to an official release. Thanks a lot!
