Not seeing ArcGIS Portal Feature Service in list of services
  • Apr 1, 2021 9:58 PM UTC
  • 138 views
aaron
Forum|alt.badge.img+12
I'm trying to write to an ArcGIS Portal Feature Service but I don't see it in the list of available services when setting up the writer. I don't own the layer but it is shared with the entire organization allowing write capabilities to all. It doesn't belong to any groups. Strangely, I can see layers in groups to which I don't even belong. I am connecting using a web connection that uses OAuth. Am I missing something? Bug? I'm using FME Desktop 2020.1.2.1 (Build 20624 WIN64).
Best answer by debbiatsafe
Hi @aaron​
This seems similar to the known issue reported in 2020.2 for ArcGIS Online/Portal Writer: Can not select existing feature service shared with a group (see https://community.safe.com/s/article/workarounds-to-known-issues-in-fme-2020x for details).
Are you able to try 2021.0 or the layer id workaround?
debbiatsafe
Forum|alt.badge.img+24
  • Apr 6, 2021 10:58 PM UTC
Hi @aaron​
aaron
  • Apr 15, 2021 3:47 PM UTC
Hi @aaron​
We are on 2020.1.2.1 in production for now but the layer ID workaround works just fine. Thanks for the tip @debbiatsafe​ !
