Multiple ws with fmeobjects.FMEWorkspaceRunner()
  • Jun 13, 2018 10:55 AM UTC
  • 100 views
jorge_vidinha
Hello, im searching for the possibility of running multiple workspaces at the same time (not queued jobs) making use of the python fme objects fmeobjects.FMEWorkspaceRunner() .
I was kind of hoping that i could pass a list of dictionarys as 'parameters' argument to runWithParameters(workspace, parameters) ...
I was expecting the same behaviour as seen in workbench transformer WorkSpaceRunner, where you can set wait for job to complete = No and the amount of jobs to run (max 7, i suppose) run in parallel.
Im i missing something wiht this object, or im really suppose to implement some python multiprocessing technic to acomplished the parallelism needed ?
What your thoughts are ?
Regards,
Jorge
Best answer by david_r
The execution of FMEWorkspaceRunner() is synchronous, so you'll have to implement your own multithreading mechanisms if you need to run several workspaces in parallel, e.g. using the Python threading module.
On the other hand, I have no idea if the fmeobjects library is thread-safe...
  • Jun 13, 2018 11:07 AM UTC
sigtill
Forum|alt.badge.img+25
  • Jun 13, 2018 12:59 PM UTC
Use rather a Custom Transformer in parallell mode. And just run that workspace once. It will spin up multiple instances. https://knowledge.safe.com/articles/1211/parallel-processing.html
jorge_vidinha
  • Jun 14, 2018 7:45 AM UTC
Thanks @david_r , somewhat taken into the incorrect assumption based on the name simililarity of FMEWorkspaceRunner() and the WorkspaceRunner transformer in Desktop. Wondering if naming the object as FMERunWorkspace() wouldnt be ok , but i dont know the background at all ...
