Issues with AutodeskBIM360DocsConnector and files larger than 500 MB
  • Nov 25, 2022 12:27 PM UTC
  • 29 views
I've automated daily uploads of certain files to the Autodesks BIM360 platform - through the use of AutodeskBIM360DocsConnector. Everything went fine the first 6 months, but as the files grew larger in size I've had issues with files bordering 500+ MB. Around 500-600 MB FME starts delivering an UPLOAD_ERROR. Is this a known issue, and does anyone have any insight regarding potential solutions or work-arounds?
Attribute(string: UTF-8): `fme_rejection_code' has value `UPLOAD_ERROR'
Attribute(string: UTF-8): `fme_rejection_message' has value `'
  • Nov 25, 2022 12:57 PM UTC
Have you verified that you're using the latest version of the FME package for this transformer?
https://hub.safe.com/publishers/safe/packages/autodesk-bim360docs
