Is AttributePivoter broken? Or is it some python integration?
  • Mar 30, 2021 5:22 PM UTC
  • 85 views
mathiku
Forum|alt.badge.img+8
AttributePivoter has started failing with a "WARN |Python Exception <TypeError>: '<' not supported between instances of 'str' and 'float'".
Prior to sending features into AttributePivoter I validate the features and they all pass as numeric .
I am aware of numerous workarounds and custom transformers - I am just curious about this error.
I hope the image is sufficient information - the Transformer Parameters are on the left hand side.
2021-03-30 19_19_24-orb-pc3789.corp.pbwan.net - Remote Desktop Connection
PS: I tried numerous python installations - including my OSGEO4W 3.7 - and both FME 2020 and FME 2021.
  • Mar 31, 2021 10:49 AM UTC
A wild stab in the dark, since I see scandinavianisms in the log (hej hej!) - is it a dot vs comma issue for the values? I.e. localization clashes where it doesn't understand decimal . vs decimal , - obviously the validator should have the same issues, so I am not super-convinced about my own suggestion.
Forum|alt.badge.img+54
  • Mar 31, 2021 11:03 AM UTC
andreaatsafe
Forum|alt.badge.img+17
Update:
This issue has been addressed in FME 2021.1 and newer
