How to use the pythoncaller when fme feature input is a matrix?
  • Feb 10, 2020 10:58 AM UTC
  • 159 views
I found the perfect python script for my needs on the net the other day.
For the first time I wanted to use the pythoncaller.
However the input for my caller is a matrix.
I'm pretty sure my matrix is correct as well as the script i want to use. I don't have a clue how to match them.
Any ideas?
The script I want to use is this one:
# Python program to find all
# rectangles filled with 0
def findend(i,j,a,output,index):
x = len(a)
y = len(a[0])
# flag to check column edge case,
# initializing with 0
flagc = 0
# flag to check row edge case,
flagr = 0
for m in range(i,x):
# loop breaks where first 1 encounters
if a[m][j] == 1:
flagr = 1 # set the flag
break
# pass because already processed
if a[m][j] == 5:
pass
for n in range(j, y):
if a[m][n] == 1:
flagc = 1 # set the flag
break
# fill rectangle elements with any
# number so that we can exclude
# next time
a[m][n] = 5
if flagr == 1:
output[index].append( m-1)
else:
# when end point touch the boundary
output[index].append(m)
if flagc == 1:
output[index].append(n-1)
else:
output[index].append(n)
def get_rectangle_coordinates(a):
# retrieving the column size of array
size_of_array = len(a)
# output array where we are going
# to store our output
output = []
# It will be used for storing start
# and end location in the same index
index = -1
for i in range(0,size_of_array):
for j in range(0, len(a[0])):
if a[i][j] == 0:
# storing initial position
# of rectangle
output.append([i, j])
# will be used for the
# last position
index = index + 1
findend(i, j, a, output, index)
print (output)
# driver code
tests = [
[1, 1, 1, 1, 1, 1, 1],
[1, 1, 1, 0, 0, 0, 1],
[1, 0, 1, 0, 0, 0, 1],
[1, 0, 1, 1, 1, 1, 1],
[1, 0, 1, 0, 0, 0, 0],
get_rectangle_coordinates(tests)
Best answer by ebygomm
The original code is here https://www.geeksforgeeks.org/find-rectangles-filled-0/
I'm not sure exactly what input you are going to have and what output you are expecting, but if you have a feature with a string representation of the matrix, something along these lines
import fme
import numpy as np
import ast
    x = len(a)
    y = len(a[0])
    flagc = 0
    flagr = 0
        if a[m][j] == 1:
            break
        if a[m][j] == 5:
            pass
            if a[m][n] == 1:
                break
            # next time
            a[m][n] = 5
    if flagr == 1:
    else:
    if flagc == 1:
    else:
    output = []
    index = -1
            if a[i][j] == 0:
                # of rectangle
                # last position
                index = index + 1
    return output
def processFeature(feature):
    tests =  ast.literal_eval(feature.getAttribute('matrixAsString'))
    result = get_rectangle_coordinates(tests)
    feature.setAttribute("result", (','.join([''.join(str(i)) for i in result])))
  • Feb 10, 2020 11:19 AM UTC
It's hard to understand what you intend to perform with the script, since indentations are missing. Could you please post the Python script containing correct indentations, using a code block?
paalped
Forum|alt.badge.img+11
  • Feb 19, 2020 2:19 PM UTC
Let the Matrix be an image then you can do raster api functions on it
Forum|alt.badge.img+54
  • Feb 19, 2020 3:36 PM UTC
import fme
import numpy as np
import ast
    x = len(a)
    y = len(a[0])
    flagc = 0
    flagr = 0
        if a[m][j] == 1:
            break
        if a[m][j] == 5:
            pass
            if a[m][n] == 1:
                break
            # next time
            a[m][n] = 5
    if flagr == 1:
    else:
    if flagc == 1:
    else:
    output = []
    index = -1
            if a[i][j] == 0:
                # of rectangle
                # last position
                index = index + 1
    return output
import fme
import numpy as np
import ast
    x = len(a)
    y = len(a[0])
    flagc = 0
    flagr = 0
        if a[m][j] == 1:
            break
        if a[m][j] == 5:
            pass
            if a[m][n] == 1:
                break
            # next time
            a[m][n] = 5
    if flagr == 1:
    else:
    if flagc == 1:
    else:
    output = []
    index = -1
            if a[i][j] == 0:
                # of rectangle
                # last position
                index = index + 1
    return output
Hi there,
Thnks for the answers all.
I did find a quick workarround.
But I am very happy with this answer. Will use it as future reference!!!
Thnks again!!!
