How does SSO for the HTTPCaller work with FME Server and Automations?
  • Jun 1, 2022 11:31 AM UTC
  • 149 views
Before implementing SSO across our services where we are using FME, I wanted to get some clarification on how SSO would work with a HTTPCaller. While this is configured in the workbench on desktop, I understand that it will use the windows user to authenticate any request. However, how does this authentication work once a workbench is published to FME Server? If we invoke a workbench through a webhook that runs Server Automation, how would the FME server know the identity to authenticate against? Has anyone encountered this before? If so, was there some way of passing a token through the webhook call that would provide identification for the HTTPcaller?
Appreciate any thoughts.
itsmatt
Forum|alt.badge.img+48
  • Jun 1, 2022 11:56 AM UTC
Good question -presumably the SSO would use the Service Account running the FMEEngine service. Not sure if that makes sense though. I'm no SSO expert
hkingsbury
Forum|alt.badge.img+73
  • Jun 1, 2022 9:35 PM UTC
Yes, it will use the Service Account running the Engines. We've experienced similar with SQLExecutor when its set to use Embedded Windows Auth
