How can I connect to an MS Access database on a separate box using FME Server running as service account? I have granted access to the to the folder to the Service Account but FME doesn't seem to like the UNC path.
  • Aug 13, 2021 11:32 AM UTC
  • 65 views
itsmatt
Forum|alt.badge.img+48
  • Aug 13, 2021 11:56 AM UTC
Hmm, UNC paths are supported. ​Most likely it's still a permissions issue.
https://community.safe.com/s/article/workspace-fails-on-fme-server-when-using-unc-paths
You'll need to make sure the the engines are also running with the correct account​
  • Aug 13, 2021 2:36 PM UTC
First, thanks for getting back to me, appreciate it! I had seen the referenced article, but I don't want to change the account for all items, I'm looking more to maybe impersonate a user for this one workspace to run under. FYI, our Network administrator set up FME Server to run under a service account and they don't want to change this.
itsmatt
  • Aug 14, 2021 12:00 PM UTC
Hmm, tricky - the best solution is really to have the engine service also run under a service account.​
http://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Running_FME_Server_Engines_Under_Different_Account.htm
I really can't think of another way you could do this. ​
hkingsbury
Forum|alt.badge.img+73
  • Aug 15, 2021 8:08 PM UTC
As @virtualcitymatt​ said, the way to get this to work is to have the engines running as the same windows service account as the core and application sever.
I imagine the only way to make seperate workbenches run as seperate accounts would be to implement a distributed FME Server Install with an engine on a seperate machine that is then running as the specified account you want. Then make use of queues to route specific jobs to that other engine.
