Getting metadata records from CSW
  • Mar 23, 2020 6:13 PM UTC
  • 106 views
I want to get and sort metadata from a CSW.
I have tried using the HTTPCaller and sent this request: https://www.geonorge.no/geonetwork/srv/nor/csw-dataset with POST and BODY:
<?xml version="1.0"?>
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2" service="CSW" version="2.0.2"
resultType="results" outputSchema="csw:IsoRecord" startPosition="1" maxRecords="15">
<csw:Query typeNames="gmd:MD_Metadata">
<csw:ElementSetName>brief</csw:ElementSetName>
<csw:ElementSetName>summary</csw:ElementSetName>
<csw:ElementSetName>full</csw:ElementSetName>
<csw:Constraint version="1.1.0">
<Filter xmlns="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml"/>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
I can see the data in the inspector but I don't know how to proceed to sort the data.
debbiatsafe
Forum|alt.badge.img+24
Hi @johsflesj
I was not able to successfully retrieve records from the service using the XML body you have provided.
But as a CSW service returns XML, I would recommend using our XML transformers such as XMLFragmenter or XMLFlattener to work with the data returned.
