FME REST: How to change ownership
  • Feb 5, 2020 7:57 AM UTC
  • 88 views
helmoet
Forum|alt.badge.img+8
Hi, I tried to find a way to change the ownership of an item in FME Server using REST API. There seems to be no possibility?
Best answer by nielsgerrits
When I test in the GUI (Security, Items, Repositories, check Repository, hit Change Owner, select other user, OK) it does a PUT on https://fmeservername.com/fmerest/v3/security/categories/Repositories/resources/repositoryname
The body is
    "owner": "newowner",
    "clientID": "repositoryname",
    "displayName": "repositoryname",
    "rolePermissions": [{
        "permissions": ["REPOSITORY_DOWNLOAD", "REPOSITORY_READ", "REPOSITORY_WRITE", "REPOSITORY_EXECUTE", "REPOSITORY_DELETE"],
        "name": "user:oldowner"
    "roles": ["user:user:oldowner"],
    "name": "repositoryname",
    "category": "Repositories"
So I think you need:
PUT /security/categories/< category >/resources/< resource > Replace resource metadata
nielsgerrits
Forum|alt.badge.img+67
The body is
helmoet
  • Feb 11, 2020 6:57 AM UTC
The body is
O wow, it works (if you replace the "user:user" by "user"). Thanks Niels!
nielsgerrits
Ah thanks for the feedback.
