FME 2020.2 I still have problems with the coordinate System writing an ecw-file. I want to write to EPSG:25832 but this is not what for example Q-GIS recognizes. I know this is an old issue but I what to know if there is any solution or workarround
  • Feb 19, 2021 8:05 AM UTC
  • 73 views
With FME 2020.2 I still have problems with the coordinate System writing an ecw-file.
I know this is an old issue but I what to know if there is any solution or workarround.
chrisatsafe
Hi @stefanj​ ,
What version of QGIS are you using? I just did a quick test and it looks like I was able to write out an ECW file with EPSG:25832 (which appears to also be labelled as ETRS89.UTM-32N) and open it up in 3.8 (although it required a transformation in my case).
2021-02-19_13-36-35
I found the bug report you are mentioning, ref FMEENGINE-33557, but it appears that was resolved in 2012 so hopefully this isn't a regression.
Could you also let me know what build of FME you are using?
  • Feb 23, 2021 11:49 AM UTC
Hi @chrisatsafe​, thanks for the quick response! I'm working with QGIS 3.10.2 and FME 2020.2 Build 20820.
I also can reproject the ecw-file to EPSG:25832 with QGIS but what I need is the correct Datum in the ecw-file for another application.
When I open the ecw with ERDAS IMAGINE I get the Information, 'Datum is undefined'.
