FME 2019: Python Caller Issues
  • May 9, 2019 1:18 PM UTC
  • 48 views
emeka_domingo
I have a workspace which was created using FME 2018. The workspace features a pythoncalller transformer which executes a script (eedc_util). The python file exist in the fmeobjects folder and workspace works fine on FME 2018.
I just installed FME 2019.0 (Build 19238 ) and when I ran the same workspace I get the following error:
|ERROR |Python Exception <ModuleNotFoundError>: No module named 'eedc_util'
Any advice on what should be done?
  • May 9, 2019 1:24 PM UTC
Try moving the Python module to the same folder as the workspace (.fmw) file.
emeka_domingo
  • May 9, 2019 3:03 PM UTC
Hello @david_r,
I tried moving as you suggested and it worked. Thanks
