CreationDate of SourceDataset to Attribute
  • Apr 1, 2021 7:42 AM UTC
  • 52 views
How do I get the CreationDate of a SourceDataset e.g. "Parks.shp" to a userdefined attribute of every Feature in this Dataset.
I tried SystemCaller and TCLCaller but got stuck.
Best answer by david_r
You can use the "Directory and File Pathnames" reader to get the file creation date (set Retrieve file properties=Yes), which you can then merge onto all the features of the shapefile.
  • Apr 1, 2021 7:52 AM UTC
  • Apr 1, 2021 8:16 AM UTC
Works! Thank you.
I never thought a Reader could help me with this Problem.
