Cannot access REST API or Web User Interface from an external network
  • Jan 7, 2021 4:15 PM UTC
  • 6 replies
  • 175 views
Hi there!
I am a testing the capacities of setting up a REST API to interact with FME Server, and I am now stuck trying to get access from an external network.
I am using
http://<yourServerHost>/fmerest/, pasting my hostname:80, but browser always reply with the “This site can’t be reached”
So, I can neither access Web User Interface from an external network
Was looking for an answer on the Forum, but couldn’t find any. Some post are around allowing firewall to get the port 80. Already did that, and nothing happens.
Do you have any suggestions?
Thank you very much,
J.
Best answer by david_r
Two things first:
  1. Hostname must be the fully qualified name, inlcuding the domain and TLD, e.g. http://myfmeserver.mycompany.com/fmerest/
  2. There must be a DNS entry for the hostname myfmeserver.mycompany.com and the server must be part of the DMZ for it to be reachable externally
These things must usually be handled by the IT department.
On a side note, I would strongly recommend using https if this is an externally visible server. See http://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/configuring_for_https.htm
  • Jan 7, 2021 4:54 PM UTC
Two things first:
Two things first:
Thank you david.
Any tips for accessing throughout REST-API a cloud hosted server? We are thinking to move the server to AWS.
Thank you!
Jorge
  • Jan 29, 2021 4:50 PM UTC
Thank you david.
Thank you!
Jorge
Shouldn't be a problem in itself, as long as the endpoints have been made accessible in the AWS firewall. I would strongly recommend configuring SSL (https) if the server is reachable from the outside.
David.,
Can i assume the same applies when configuring an "Amazon SNS topic notified" trigguer? When I am configuring the subscription, I am not getting what the 'endpoint' should be? the FME guide said> "Enter the web address of the FME Server Amazon SNS Publisher " . https://docs.safe.com/fme/html/FME_Server_Documentation/ReferenceManual/Amazon_SNS_Publisher_Configure_AWS_Subscription.htm
  • Feb 1, 2021 8:48 AM UTC
David.,
In principle, it's the same thing. But AWS has some added functionality that can both help and complicate matters. You may want to look at the documentation for SNS from AWS as well: https://aws.amazon.com/sns/resources/
Safe has also published a sample workspace using SNS that my be helpful: https://hub.safe.com/publishers/safe-lab/templates/amazon-sns-example
Cool, I made it through SQS (SNS to transmit the message) and it works ok! Thank you
