Can't read SOAP
  • Sep 11, 2019 1:06 PM UTC
  • 86 views
zzupljanin
Forum|alt.badge.img+5
I'm having difficulties understanding SOAP in FME. I followed through https://knowledge.safe.com/articles/45314/working-with-soap-services.html but I always get 500 Internal Server Error.
Using SOAP UI everything goes smoothly (see pictures bellow) but in FME I just can't get it running correct.
It uses this SOAP schema: https://oss.uredjenazemlja.hr/OssWebServices/services/AuthenticationService.wsdl
Can you please show my what I'm doing wrong.
Cheers,
Zelimir
Best answer by daveatsafe
Hi @zzupljanin,
Your upload SOAP request looks correct. The only problem I can see is the URL in the HTTPCaller, which is:
instead of:
itay
Forum|alt.badge.img+19
  • Sep 11, 2019 1:26 PM UTC
Hi @zzupljanin,
I am currently also getting a error from the service
Are the credentials in the workspace correct? otherwise the authentication step reject the user credentials.
zzupljanin
  • Sep 11, 2019 2:54 PM UTC
Hi @zzupljanin,
Unfortunately,
I took the liberty to not provide it.
You'll have to trust my word.
I'd be grateful for any tips & tricks for understanding SOAP schema to provide correct request in FME.
daveatsafe
Forum|alt.badge.img+24
  • Sep 11, 2019 4:53 PM UTC
Hi @zzupljanin,
instead of:
zzupljanin
  • Sep 12, 2019 7:34 AM UTC
Hi @zzupljanin,
instead of:
Solved it
You're right about request url.
Other thing I had to do is to use Text (text/plain) in HTTPCaller instead of SOAP XML (application/soap+xml).
Thank you
