ArcGIS Pro Data Interop Extension Intermittent Connection to Writer Database
  • Jan 21, 2023 2:30 PM UTC
  • 65 views
Using ArcGIS Data Interop extension to build workbenches. We are connecting to an external database to write to and we are experiencing intermittent connection. When testing connection, when it fails we get a timeout error. Same when when we run the workbench. But then sometimes it will connect fine and run the workbench as expected. Anyone else experience this?
Best answer by evieatsafe
Hi @klavoie​ unfortunately, we aren’t aware of any known connectivity issues when working with databases in FME and these kinds of issues can often come down to factors within the specific environment like network connectivity, database updates, permissions, etc.
Esri handles support for the data interoperability extension, if you have data interoperability specific questions it might be helpful to post them to that specific forum found here: https://community.esri.com/t5/arcgis-data-interoperability/ct-p/arcgis-data-interoperability
evieatsafe
Forum|alt.badge.img+28
  • Jan 31, 2023 7:34 PM UTC
