ArcFM Autoupdater is not invoking a object or feature on create event using FME
  • Sep 30, 2020 3:58 AM UTC
  • 56 views
ArcFM autoupdater in not invoking ​on feature create event using fme. in start up python script initializing arcfm license. I could see arcfm system autoupdaters are working but custom AU which is assigned in feature on create is not firing. Please help
chrisatsafe
Not sure if you've already checked it out, but perhaps the Using FME to Write to ArcFM Geodatabases might give you a possible solution?
https://community.safe.com/s/article/using-fme-to-write-to-arcfm-geodatabases
https://community.safe.com/s/article/reading-arcfm-geodatabase-data-using-fme
