Access to download logs from notification url without logging in.
  • Sep 23, 2019 5:55 PM UTC
  • 86 views
jdh
Forum|alt.badge.img+41
Scenario, we have a webapp that uses the rest api to run workspaces.
User does not have an account on FME Server.
User interacts with the web app. User receives an email that includes a link to the log file.
How can I set up FME Server permissions so that the user can simply download the log file from the email link without having to enter a username/password?
This should be the absolute minimum required permissions. Ie there should be no unauthenticated access to run the jobs themselves.
itay
Forum|alt.badge.img+19
  • Sep 23, 2019 6:05 PM UTC
Hi @jdh,
What about sending the log as an attachment instead of the link to it?
jdh
  • Sep 23, 2019 6:10 PM UTC
Hi @jdh,
That becomes problematic as the log hasn't finished writing when the notification is triggered.
The workspace has a Terminator immediately after the FMEServerNotifier that triggers the email, so I'm not terribly concerned about race conditions.
itay
  • Sep 23, 2019 6:16 PM UTC
I see, this is not the best solution for such a construction. I would trigger the topic once the workspace is done.
jdh
  • Sep 23, 2019 6:22 PM UTC
So the problem with triggering the topic when the workspace is done, is that the "Post Data from Writer" setting only works on Success, not on Failure.
Otherwise I would absolutely use a FeatureWriter -> Terminator, Post to Topics on Failure solution.
(Which is how the emails are set up when the workspace is successful).
