1st parameter `XZJ' is not a floating point number
  • Dec 15, 2019 5:43 AM UTC
  • 30 views
charry
Forum|alt.badge.img+5
Execution error? 1st parameter `XZJ' is not a floating point number?BUT I can't XZJ type
Best answer by takashi
Hi @charry, the performFunction method requires a string representing a complete FME function call as its parameter. If the FME function (@Rotate2D in your case) requires a numeric value as a parameter, it should be a numeric representation, should not be any attribute name (string).
e.g.
    feature.performFunction('@Rotate2D(45,0,0)')
If you want to pass feature attribute values to the FME function, you will have to build the FME function call string containing appropriate values as formatted strings.
e.g.
    a = float(feature.getAttribute('_angle'))
    x = float(feature.getAttribute('_x'))
    y = float(feature.getAttribute('_y'))
    feature.performFunction('@Rotate2D(%f,%f,%f)' % (a, x, y))
By the way, why not use the Rotator transformer?
  • Dec 15, 2019 8:36 AM UTC
e.g.
e.g.
