workbench with different psrameter
  • Sep 2, 2020 5:48 PM UTC
  • 54 views
Hi, I have published ​a Workbench on FME Server. I want to repeat the process with different psrameter like workspacerunner. I try this with fmejobsubmitter without success
Thanks ​
siennaatsafe
Forum|alt.badge.img+12
Hi @jeppenbe​ ,
I'm sorry you are having trouble using the FMEServerJobSubmitter. Would you mind expanding on why it isn't working? Are you getting any errors?
What version of FME Server are you using? If you are using a newer version of FME Server, you can accomplish something similar using FME Server Automations. You can look at using the Automations Writer to pass parameters from one workspace thats run to another https://community.safe.com/s/article/building-integrations-with-the-fme-server-automati
  • Sep 5, 2020 11:35 AM UTC
Hi @jeppenbe​ ,
I'm not sure, but the FMEServerJobSubmitter must be triggered via a local Workbench? But the link which you sendet could help me
Thanks and best
