Unable to run the FME workflows through server:
  • Aug 20, 2019 5:00 PM UTC
  • 51 views
Unable to run the FME Master workflow which has 39 workflows as single workflow through FME Server. It used to run fine until 2 weeks back. Now,It is returning an ORA-12154 error in the log file. Please help
2019-08-19 06:00:14| 0.8| 0.0|INFORM|Feature Type: `FEATURE_TYPE'
2019-08-19 06:00:14| 0.8| 0.0|INFORM|Attribute(string): `_reader_error' has value `Error connecting to Oracle database: message was `ORA-12154: TNS:could not resolve the connect identifier specified'. (serverType=`*****', serverName=`*****', userName=`', password=`***', dbname=`')'
2019-08-19 06:00:14| 0.8| 0.0|INFORM|Attribute(string): `fme_type' has value `fme_no_geom'
2019-08-19 06:00:14| 0.8| 0.0|INFORM|Geometry Type: Unknown (0)
sipsysigh
Forum|alt.badge.img+12
  • Aug 20, 2019 5:12 PM UTC
Do you connect to Oracle using local naming (tnsnames.ora file)?
If so, you might want to check the following:
  • Verify that a tnsnames.ora file exists and is in the proper directory and is accessible.
  • Check that the net service name used as the connect identifier exists in the tnsnames.ora file.
  • Make sure there are no syntax errors anywhere in the tnsnames.orafile. Look for unmatched parentheses or stray characters. Errors in a tnsnames.ora file may make it unusable.
Simon
