Unable to restore fsconfig backup after FME Server upgrade to 2020.1.3.
  • Jan 6, 2021 3:24 AM UTC
  • 82 views
aguan
Forum|alt.badge.img+11
I upgraded our production FME server from 2019.2.1 to 2020.1.3, but restoring/importing the fsconfig file which was backed up from 2019.2.1 did not do anything. Did not see any errors though. I did the same upgrade on our test server two months ago without any issues. Wondering if anybody had experienced the same issue or knew how to diagnose the issue.
Contact support. They will help you fix it asap.
aguan
  • Jan 6, 2021 1:53 PM UTC
Don't know why, but when I copied the fsconfig file to local drive, then upload/import succeeded. Problem solved.
