Problem in Server FME Server 2018.1.1.2 - Build 18586 - win64 , SUCCESS with a FATAL Error?
  • Nov 1, 2019 12:27 AM UTC
  • 60 views
dewrightco
We have a set of jobs that feed a enterprise system that are pushing into a Enterprise GDB. We just found in debugging that a fatal error:
An error occurred while attempting to retrieve the connection parameters from the connection file 'C:\\Users\\ahdor140\\Downloads\\GCSS_PROC - GIS.sde'A fatal error has occurred. Check the logfile above for details
Our issue is that with this fatal error; the job is reported as:
statusSUCCESS
This doesn't seem right to me.
sigtill
Forum|alt.badge.img+25
  • Nov 1, 2019 11:40 AM UTC
Hi @dewrightco
1. Check if Terminate Translation is active on the workbench before uploading to server
2. Add a "NoFeaturesTester" after the reading of the ArcSDE data and if NOINPUT add a Terminator to make the workspace fail
