Logging to FME Server fails,
  • May 12, 2019 3:34 PM UTC
  • 54 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out why I’m getting the message shown in the screenshot below:
“couldn’t connect to FME core”
In addition to that, Windows fails to start the FME Server Core.
What could be the issue here?
Hi @jamal
Can you check that local system is able to have read/write access to the FME Server System Share (specified in install)? You may need to go into that directory and ensure local system has cascaded access.
Also please be aware that FME Server 2015 is considered a mature release and will no longer be supported next year, I'd strongly recommend installing the latest release.
jamal
  • May 14, 2019 10:17 PM UTC
Thank you jlutherthomas for the help
As per the screenshot below, everyone has full control on the file, however, the issue persists to exist
