Linux FME Server ArcPy
  • Mar 25, 2022 5:40 PM UTC
  • 98 views
We are implementing FME Server, we have set up server core components on one machine using docker-compose and engines on different machines using docker.
All these are done on Linux, the host is a Linux machine and all component is running on Linux containers.
I do have a few users who have jobs that have a dependency on arcpy. I came across this article ArcPy on FME server (safe.com). This is more about windows, is there any way to support arcPy with FME on Linux environment?
Thanks,
Naman
hkingsbury
Forum|alt.badge.img+73
  • Mar 27, 2022 8:00 PM UTC
I'd reach out to support, but in short, i don't think its going to be possible. For ArcPy, you need to have ArcObjects which in turn needs to have a valid Esri license and install
  • Mar 28, 2022 7:52 AM UTC
In theory it should work if you install ArcGIS Server for Linux on the same machine as FME Server.
Just be sure to verify version number compatibility first: https://community.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility
