httpcaller token syntax
  • Aug 18, 2021 7:40 PM UTC
  • 117 views
mferwerda1111
Participant
I am probably missing something really simple here, so I am looking at this example:
https://community.safe.com/s/article/streaming-geojson-with-fme-server-2016
I create a webhook, which gets me the URL and token.
So I then try to use a httpcaller from FME desktop to call that webhook, and pull down the data, but just putting this url in the httpcaller
https://myfmeserver/fmedatastreaming/testing/GeoJson.fmw?FEATURE_TYPES=Default.BusRoutes&token=f57z2802-4a5f-edcb-87fa-16c849facdce
But I get 401 unauthorized, is that not a valid syntax for adding the token to the URL? I also tried adding in the header dialog boxes, got the same.
hkingsbury
Forum|alt.badge.img+73
  • Aug 18, 2021 7:53 PM UTC
The value you're entering there doesn't look like a token. A token should be 40 characters long with no dashes. It looks like you might be using the GUID of the token.
See wome more details here on how to set the token in calls
https://playground.fmeserver.com/using-the-rest-api/basics/
mferwerda1111
Participant
  • Participant
  • Aug 18, 2021 8:28 PM UTC
When you gnerate a webhook, FME creates a token on the fly, and it does have dashes, when I look under tokens in FME server, I see it listed as a "Session token", it seems those have dashes. When I manully generate a token, it is does not have the dashes, but I get the same 401 unauthorized error with that as well.
mferwerda1111
Participant
  • Participant
  • Aug 18, 2021 9:07 PM UTC
So the syntax does work with the token (with the dashes) in the httpcaller, as long as I do not use the GET command, so apparently, that is not supported.
