How to uninstall the FME Server 2021?
  • Dec 11, 2022 3:34 AM UTC
  • 85 views
defence_hyang
Participant
I tried to uninstall using the FME Server installer (EXE) file, the status stay at "removing files" for long time without progression.
I tried to uninstall the server from Windows control panel, the process hangs as well.
I need to reinstall the server from C:\\ to D:\\ drive, the repair does not allow me to do that.
Please advise how I can remove the Server 2021 from Window 2019 server platfor.
Thanks
Helen
matt.m-at-safe
Forum|alt.badge.img+14
Hi @defence_hyang​, The process can take a while, have you tried leaving it alone to see if it finishes? Is there a Windows prompt that may be halting the uninstall that is hidden by other windows? Are you uninstalling as an Administrator on the server machine?
defence_hyang
Participant
  • Participant
  • Dec 16, 2022 3:15 AM UTC
Hi, Thanks for the reply.
I did wait for 2 hours, and no progress. I endup manually deleted files from locations and window registry.
