How to delete unused resource folders?
  • Mar 4, 2022 12:36 AM UTC
  • 95 views
brandonguo
Forum|alt.badge.img+7
I created some shared file resource folders by editing the fmeServerConfig.txt file.
Then after I removed the new shared source codes and restarted the server, the folder still displays under the web interface. How do I delete those unused folders?
Thank you.
  • Mar 4, 2022 7:30 AM UTC
Depends on the version of FME Server, but if you log on as a superuser it might be possible to delete the resource folder from the web GUI.
brandonguo
  • Mar 6, 2022 9:14 PM UTC
When I try to remove it from the web GUI, it pops up with the following error message.
  • Mar 7, 2022 8:09 AM UTC
It may be that there are some lingering references to the non-existant share in the FME Server database. You may have to contact Safe Support for assistance.
