FMEservreJobSubmitter connection
  • Feb 2, 2021 7:25 AM UTC
  • 50 views
fme_hans
In a workspace I used a few FMEServerJobSubmitters. It worked fine for a few days but suddenly the error message “credentials for user are invalid”.
I can still login to the FME server with the same credentials as the workspace works with. How is it possible that these credentials are not held?
Greetings
kailinatsafe
Forum|alt.badge.img+24
Hello@fme_hans​, the fact it was previously working leads me to think it could be your user account. Are you able to verify if any changes were made to your account’s permissions recently? (Particularly for running the workspaces you have in FMEServerJobSubmitter). An easy way to check this, try running the workspace from the FME Server web UI. Let me know if you make any progress. Also, have you tried any of the suggestions listed in FME Server Troubleshooting: FMEServerJobSubmitter Guide for roles and users?
Here to help,
Kailin
fme_hans
  • Feb 4, 2021 7:09 AM UTC
The are no changes to my user account. The workspace runs fine when i download it from FME server. After i upload it it will work for 1 or 2 days and then i get the same warning.
