FMEServerJobSubmitter issue
  • May 10, 2022 10:20 AM UTC
  • 124 views
nicolae.soare
Forum|alt.badge.img+3
I am using FMEServerJobSubmitter in a workspace to submit jobs in sequence for another workspace in repository.
Both workspaces were successfully published on FME Server.
When I run the one containing FMEServerJobSubmitter, I get an error saying that "user is not authorized to perform this action". I mention here that I am logged with admin also and have full rights in FME Server, but I still get this error.
Any ideas?
Cheers,
Nicu
Forum|alt.badge.img+63
Just to be sure: can you doublecheck whether your account has the proper permissions for the repository you're trying to run the workspace from? It should have at least Read and Run. I'm guessing it does, because otherwise you wouldn't be able to select it, but you never know...
nicolae.soare
  • May 10, 2022 10:38 AM UTC
I am able to run other workspaces from that repository.
nielsgerrits
Forum|alt.badge.img+67
Did you recently upgrade your FME server and did a restore? Then you probably have to update the access permissions on the connection files.
  • For the user:
    • User Management - Users - select user - Permissions - Connections.
  • For other tokens:
    • User Settings - Manage Tokens - select token - Permissions - Connections.
