fmedatadownload Respoonse URL has wrong protokoll and host
  • Apr 28, 2021 9:15 AM UTC
  • 74 views
Hey there
We have updated our FME Server to Version 2021.0.1.
Now we have a small problem with the fmedatadownload service. The Workbench works fine, and it also returns a URL. But the returned URL has the wrong protocol and not quite the right host.
We have the following request:
https://fmesvr.company.com/fmedatadownload/...?opt_servicemode=sync&opt_responseformat=json
The response URL looks like this:
http://fmesvr/fmedatadownload/results/...
If we change the download URL to the right protocol and host the download works just fine.
Obviously we have some Settings wrong. Can anyone help witch config files are wrong?
Hi @lucasoertli​ ,
The data download URL link is generated using the value specified for the Service URLs. Please go to System Configuration > Network & Email > Services and I'd recommend you 'Change all Hosts'. Note, if you are not the FME Server Administrator you'll need help from them to update this.
Wow, that was super easy. We searched for some hard coded config files. 😅
Thank you very much, works just fine.
