Error opening dataset '' for writing... on FME Server
  • Nov 12, 2020 2:13 PM UTC
  • 187 views
Hello, I'm trying to run a worspace on FME Server ...locally it works well, but on FME Server this error is shown every time it is run...
Error opening dataset '' for writing, ensure that file path and permissions allow for writing
The XML Module halted on error, see the logfile for details
MULTI_READER(R_10): Skipping to next Reader
Does anyone know how to solve this?
  • Nov 12, 2020 2:15 PM UTC
Are you perhaps trying to write to a network drive or to a UNC path?
If yes, make sure that the server engines are running as a domain user, see https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Running_System_Services_Under_Different_Accounts.htm
