Disabled Nuker -1 50 (TeeFactory): ?
  • Jul 19, 2022 8:05 PM UTC
  • 5 replies
  • 214 views
jhawks
Forum|alt.badge.img+7
Server Log Error: FME Server 2022.0.0.2
2022-7-19 11:15:03 | AttributeFilter_FAIRWY Disabled Nuker -1 50 (TeeFactory): Feature specification `NO_LOGGING' in mapping file row `FACTORY_DEF * TeeFactory FACTORY_NAME AttributeFilter_FAIRWY Disabled Nuker -1 50 INPUT FEATURE_TYPE AttributeFilter_FAIRWY NO_LOGGING' is not valid -- it has an invalid number of entries
merlinegeorge
Hello @jhawks​ ,
Could you please confirm if you are also seeing this error when you run this workspace on FME Workbench? Or is this on only FME Server?
Could you also please send us a copy of the workspace and the full job log?
jhawks
  • Jul 21, 2022 3:29 PM UTC
Server. Here's the Log.
jhawks
  • Jul 21, 2022 3:30 PM UTC
and Workbench
merlinegeorge
We usually see errors that reference ‘factory’ in some way are usually related to version compatibility issues. Is the FME desktop that was used to create the workspace newer than the FME Server version that you are running the job on ? Since FME is not forward compatible, FME Server would have to be at the same or newer version than the FME Desktop.
jhawks
  • Jul 25, 2022 12:47 PM UTC
We made Desktop and Server the same version and that's helped! Downgraded Desktop, quicker than upgrade Server, both 2022.0.0.2. Still getting this odd error:
2022-7-25 08:34:10 | Python: There is a known Windows bug that may cause instability when using Python in the current locale. Please update to Windows 10 version 2004 and greater, or to Windows Server 2022
Also this: 2022-7-25 08:34:45 | AreaOnAreaOverlayer (OverlayFactory): Overlaying requires a tolerance of at least 3.6000000000000033e-13 for these features, and the input tolerance is 0. Setting the tolerance to 3.6000000000000033e-13
