Credentials to log in on FME Server in FME Labs for FME Academy.
  • Feb 11, 2023 9:10 AM UTC
  • 158 views
diethard2
Forum|alt.badge.img+4
In FME Academy I follow the trail 'Publish Workflows to the web' and use the FME Virtual Machine created in Strigo. In topic 3 Exercise: Publish to FME Server the webconnection 'Training FME Server' allready exist, so I can publish my workspace, which works fine. But in the next excercise I need to login with given credentials in topic3. I assumed I could use the same credentials but the password 'FMELearnings' is not the password I can use to login. I would like to know where I can request the correct password. It would be nice if the login to FME Server in the VM would use the same credentials as given in the exercise!
Best answer by ryanatsafe
The username should be admin and the password should be FMElearnings with a lowercase 'l'.
ryanatsafe
Forum|alt.badge.img+11
  • Feb 14, 2023 3:50 AM UTC
