After upgrade FME Server to 2020.1.3 python (2.7) is not working anymore. How can i fix this?
  • Nov 2, 2020 11:04 AM UTC
  • 120 views
francis
Forum|alt.badge.img+16
We get the following errors:
2020-10-29 17:09:30 | Python Exception <ImportError>: No module named fmeobjects
2020-10-29 17:09:30 | Failed to import `fmesite'
During installation i did not choose to install python2.7 because arcgis desktop 10.4.1 is already installed on the server. Also i encountered never issues with python before during previous upgrades (2018,2019).
I already tried to run a repair but i can't select the option to install python2.7 during this process.
I found this:
FME Server 2018.1 and later
<FMEServerDir>Server/fme/fme.exe APPLY_SETTINGS SYSTEM "Python/Use Custom Python <32|64>" true
<FMEServerDir>Server/fme/fme.exe APPLY_SETTINGS SYSTEM "Python/Python Interpreter <32|64>" c:/<path_to_dll>/python27.dll
<FMEServerDir>Server/fme/fme.exe APPLY_SETTINGS SYSTEM "Python/Custom Python Home <32|64>" c:/<path_to_python_home>
In this case can i point to C:\\apps\\FMEServer\\Server\\fme\\fmepython27.dll?
Thanks a lot!
Best answer by francis
i did a reinstallation with install of python2.7 and it solved the problem.
Thanks
danielkroon
Hi @francis​ ,
I don't have an answer to you questions, but an important question:
Is the python version 2.7 a requirement, or can you go with the python 3.x series?
Python 2.7 is becoming more and more legacy.
I hope you will get a good answer that help you soon!
Daniel
francis
  • Nov 2, 2020 12:42 PM UTC
Hi @francis​ ,
Daniel
it is a requirement for us because we are working in an arcgis server enterprise environment (10.4.1) and still use arcmap
francis
  • Nov 2, 2020 3:27 PM UTC
Thanks
